Old 10-15-2016, 04:44 PM   #1
thstone
The knock sensor detects knock or (more correctly) pre-detonation in the cylinders by sensing the harsh vibrations. The ECU will then retard the ignition timing to prevent engine damage. Retarding the timing usually results in a loss of power so the engine can feel weak. The ECU will set the check engine light (CEL) if the sensor or wiring fails.
