Old 10-15-2016, 01:11 PM   #11
ChrisZang
ChrisZang's Avatar
I had the same problem and had to replace the PS pump as a plastic part which is an integral part of the pump had melted
Here is what I did
1) Replace the Pentosin PS fluid with Redline (it has a higher boiling point and is less likely to create bubbles)
2) underdrive pulley
3) I installed a PS cooler (I think it was from LN Engineering) which was a major pain in the neck to install
