Old 10-11-2016, 11:16 AM   #25
RichRobby
If you are getting P0300 series misfire codes, your coils or plugs are most likely the issue. I'd start there. And if this is the case with the codes, the Durametric is not going to tell you any more; you need to start doing close up diagnostics to ID the source.
I've now got the Durametric - and how right you are. It is showing a misfire code and nothing more. Guess I will now be getting my hands dirty and starting with the plugs and coils.
I might regret getting the Durametric now that I see the ignition range readings. From my limited understanding of them the over revs look very high!
Range 1 33785 / 2232 Hours
Range 2 145 / 372 Hours
Total Hours 2257
I assume range 2 at 145 is not good but at least it was a long long time back - is that correct? (Current mileage is 61000 by the way).
Is there anything in particular I should now check with the Durametric (other than fault codes)?
RichRobby is offline   Reply With Quote
