Originally Posted by jimtucker
I have a 2003 Boxter S and want to replace the entire secondary air system. I've already replaced the pump, but that did not solve my problem (check engine light and P-codes pointing to secondary air}.
Does anyone know where on the engine the other components are located and the easiest way to get to them for replacement?
I would appreciate any help or hints.
Thx,
Jim
I just Googled it and here you go. All the components are reached from the top. Change out the plastic vacuum tank (shown in diagram) as they can crack and cause a leak.
