Old 10-05-2016, 02:29 PM   #15
911monty
911monty's Avatar
While you can activate the system using the Durametric, it is not set up- to read voltages. That would be better accomplished with a multi meter or Power Probe tool.
Yes, my bad attempt at brevity. That's what I meant when I said "test" for voltage. However it seems like a simple test for continuity and command from the DME.
