Old 10-05-2016, 08:47 AM   #18
stelan
stelan's Avatar
There is one more remote posibility: aos relies on a small return than can be partially obstructed, when you remove the aos put a hose in the tiny hole in the block, and blow with your mouth to see if is free
Maybe an old aos seal or something, if not draining fast you can have almost half quart of oil up there ready to be sucked into the tb, however I vote on another bad new aos
stelan is offline   Reply With Quote
