Old 10-03-2016, 05:51 AM   #1
itsnotanova
Originally Posted by Anker View Post
104K miles, so it is very likely the engine mount as you suggest.
Looks like a breeze to swap it out.
Thanks rexcramer/Anker
With that many miles you may want to check your transmission mounts too. That's real easy to check. Where the transmission mounting brackets meet the transmission mount is a large bolt. Look up that bolt and see if any fluid is leaking out. Leaking=BAD. You'll probably have some suspension pieces that are bad too
Woody
