Old 09-20-2016, 07:03 AM   #33
Deadeye
You could also try loosening the bolts that hold the aluminum bracket to the chassis, get all studs to line up and then tighten all nuts & bolts to spec. Strongly recommend an alignment after this as this may change your rear toe.
Deadeye is offline   Reply With Quote
