Old 09-17-2016, 09:42 AM   #13
madmodz
madmodz's Avatar
Thank you Radium,
I read an old post that I think you linked the going superfast.com link to. I was amazed at the brains and the machining they did to cut off the horizontal mounts on the cayenne and then drill the caliper for radial mounts. Bloody amazing!
The Girodisc conversion is basically what I am doing on the cheap. The Girodisc are beautiful though.
Looks like Porsche increased the rotor size from 330mm to 340mm on the Carrera S and 4S.
The girodisc is 340mm. They must be running thinner disc then the Carrera since no retainer pin modification is needed.
Thanks for the brake caliper stud kit. 4 different lengths too. I will go this route down the future.
Hello madmodz.
seems to be 991 brake discs.
991 Carrera S and 991 Carrera 4S do have 340 x 34 mm in front and 330 x 28 mm in the back.
They use a 6 piston monobloc caliper in front and a 4 piston monobloc caliper in the back.
Only thing i'm not shure of is the hole pattern.
Regards, Markus
Thanks Markus,
Bolts right up with the hole pattern.
So help my simple mind on an early Sat morning...
If you've ground off the pad retaining pins, how do you plan to keep the pads in place?
I was reading a caliper conversion on the vw forum I think or audi forum. The guy had masking tape around the ends of the pins and it said cut off in the pic. I said to myself how the hell is he going to hold the pads in too lol. Let me post a pic of the retaining pins Im talking about. I don't want to confuse the pad guide pins to with the pad retaining pin and clip on top. These are four retaining pins that look pressed into the caliper.
I was hoping to steer the conversation this way today. So I ask, are there replacement pins? If there are, that means they are replaceable and a way to remove them. Using a press?? One of my rear calipers seems to have this pin pressed in a little more so its not flush with the body. I don't have a press in the shop. If they are pressed it would be easier to lathe them down and repress them in the caliper as they are difficult to cut. Somebody could even offer shorter pins.
The article of the vw modification said file these four pins down. I would suggest that you cover the pistons in masking tape to keep any shavings out of there if you go this route. These pins did not file easily at all and my dremel didn't make a dent on them. They have to be stainless. I used a grinding disc which worked.
So the purpose of grinding down the 4 pins is to allow the thicker Carrera rotor to fit into the S caliper. The Carrera rotor is thicker so the pins block it from going in. In this pic there is a base rotor, a S rotor and the 340mm Carrera rotor I'm using. Look at the different thickness of the rotor.
So Husker, your not really changing anything, great question. I wondered about it too. The Carrera rotor thickness makes up for the amount you cut down. Your taking mm from the pin but equaling the amount with the extra mm from the thicker rotor. The four pins act as a guide for the backing pad on the brake pad not the brake pad.
So two issues so far:
(1) If you modify your pins, your running Carrera disc for now on. No more S rotors. Unless someone can answer are those pins replaceable, there is no turning back. I don't really see this as an issue though, since you have thousands of conversions running these calipers. Let the next owner of the car know though.
(2) Since the rotor is thicker, I had to push the pads back into the piston to fit. My pads looked pretty thick. I was wondering how much room there is if the pads are brand new. I will look at that angle this afternoon.
Thank you all for your contribution. If all the vw and audi and countless other cars can do it, we can do it. 330 or 340 rotors on the S for whatever you find the price of the rotors. Sorry for the grammar.
madmodz is offline   Reply With Quote
