Old 09-13-2016, 04:37 PM   #1
thstone
Originally Posted by hoyabob2003 View Post
Thank you. I actually read your thread - 3 times - before I posted this. I just wasn't clear how it all ended up - did you mate the housings before tightening down?
Yes, when everything is aligned it will slide back together by hand with a little push - no significant force required.
If its not sliding back together, try rotating the big gear through the hole a bit to make sure that the drive shaft splines are aligned.
If that doesn't work, you'll have to do some sleuthing to figure out where its being held up at/from.
