Old 09-12-2016, 07:43 PM   #4
sleepingboxster
Shave master
OK. I replaced the spark plug tubes and Removed and reinstalled the existing AOS. The leaking tube had a missing chunk the size of a dime. I don't know if it broke when I removed it or if it was broken from putting a spark plug socket in there when I changed the plugs last month. I left the dime size piece of plastic in the valve cover as I couldn't fish it out and thought I'd cause more harm than good by removing the cover especially since I don't know when it broke off. I used the ERO brand tubes they were a very tight fit I really lubed up the rings then pretty much had to force it. They were 2mm longer than the original ones and at first I thought that may be the problem, but it's just tight O-rings. Idle is much better from 700 to 1050 RPMs instead of 11 -1500. It did not immediately turn off the check engine light, but I did reset it and after about 33 miles is has not come back on and there are no pending faults. I'm hopeful but there could be additional leaks - I was expecting no higher than 850 RPMs.(what is normal?) Hiss is gone. I'll give it another 60 miles and they put the carpet and rear speakers back in! Huzzah!
sleepingboxster is offline   Reply With Quote
