Old 09-12-2016, 05:01 PM   #12
jamesmcd03
Confused?
Do you have photos or videos on how to do this? Not clear on how to access this area.
"first place I would look is at the end of each of the two cables that drive the transmissions. You can check them for length to make sure that they are being driven by the electric motor by first lifting up the upside down U clip that holds them against the sides of the electric motor. If the inner cable is not sticking out by about 1/2 inch from the end of the outer sheath, that is probably your problem. Otherwise, you will have to investigate at the other end of the cables (the transmission end).
Thank you,
jamesmcd03 is offline   Reply With Quote
