Old 09-05-2016, 08:05 PM   #1
Gilles
You are going to need more than that. Pulling the valve cover requires the use of a cam holding tool (home brew version in the lower right of the photo, small drawing is the factory tool
This and the caps need to be installed to hold the cams against the spring pressures while the cover is removed. Without these tools you risk breaking both cams when the cover is removed.
JFP,
Yes, I was planning to use the cam locking tool before attempting to loose the bolts on the valve cover, but honestly never tough about using the center holding fixtures since I was planning on removing the covers, clean them thoroughly, applying a thin bead of sealant (Curil T..?) and reinstalling the covers right away.
Thank you for your comments!
