Old 09-03-2016, 07:01 PM   #14
Ben006
Ben-Auto-Design
Ben006's Avatar
Leaks oil from where ?
Reconnect everything and measure crankcase vacuum through the oil filler.
If you don't have a gauge accurate enough, make one:
This is a water column pressure gauge, one end is open to atmosphere and the other to the crankcase (it has to be air tight). You then look at how far the water level at multiply by two to have the pressure in In of water column (InWC).
It should be 4 to 6 InWC of vacuum.
What engine do you have?
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
