Old 09-03-2016, 10:14 AM   #1
sleepingboxster
Shave master
Identify this part!
I have a p0507 CEL with eratic iddle and a hiss from somewhere in the engine bay, I suspect the problem is a vacuum leak from some where after the air oil separator. If I disconnect the breather hose from the AOS and block it off the intake side, the hiss goes away and idle returns to normal. But then I am left with a puddle of oil under the drivers side. I suspect that the oil and vacuum leak are coming from where the AOS connects to the left head. I believe this is the part that connects the head to the hose leading to the AOS. It has a funny springed vent facing the camera and the whole part was covered with dirty oil. I'd like to know what the function of the spring mechanism is to see if I can just seal off the vent. I'd also like to know the name / part number of this head breather vent thing so I can replace it.
This picture shows the part looking at the engine from behind the drivers seat firewall cover removed (USA left hand drive) and is under the intake manifold.
sleepingboxster is offline   Reply With Quote
