Go For it!!! The $100.00 deductible sounds like a deal....see if it can be extended to 100k miles......My 98' is also a daily driver and I'm currently at 130k miles on the clock...major shortcomings started at around 70k miles....You may (or may not) run with the proverbial RMS deal. Although if there's no leak thus far maybe you'll not get it at all..I know I don't have that problem, but I did run into other headaches...Like Cooling system, one of my fans seized ($180.00) which created overheating and evetual cracking of the coolant reservior tank ($280.00) which in turn made one of the front radiators to leak ($340.00)...Or when the AC evaporator ($370.00) turned to swiss cheese leaking freon in the blower unit and I had to tear down the entire front dash ($400.00) to get it replaced......yeah it would have been nice to have an extended warranty then.
The coverage issue is also a good point before signing up, find out if it's a bumper to bumper deal, not including wear parts of couse, and if that's the case laike I said, go for it!!!
