Old 08-30-2016, 06:02 AM   #2
steved0x
steved0x's Avatar
Originally Posted by FauxDiablo View Post
If you are going to replace the springs anyway, just remove and install them while the struts are in the car...it may seem daunting, but it's 10 times easier than removing everything else.
You are looking at an alignment anyway due to the lowered springs, so I guess you could disconnect the toe arm and the LCA at the body side (where the eccentric bolts are) and not fool with the ball joint end at all I was replacing my LCA anyway so I had to remove the ball end...
