Old 08-29-2016, 07:33 PM   #1
FauxDiablo
If you mean you are going to remove the rear struts, replace the springs, and reinstall, you can do it. I used that same guide. Roughest part for me was getting the LCA ball joint ends off, but I did it So you can too
If you are going to replace the springs anyway, just remove and install them while the struts are in the car...it may seem daunting, but it's 10 times easier than removing everything else.
FauxDiablo is offline   Reply With Quote
