Old 08-29-2016, 03:13 PM   #1
Luv2Box
Luv2Box's Avatar
You might try removing the belt to see if the noise goes away with belt removed. It's ok to run a few minutes with no belt. However from that last video with the battery discharged, I would check the spark plugs. A loose plug can make a chirp like that.
I had the same sound and 911 monty is correct it was a loose plug that had not been tightened correctly.
Luv2Box is offline   Reply With Quote
