Old 08-22-2016, 04:24 PM   #30
jcslocum
Project Addicted
jcslocum's Avatar
Bolting is what I do for a living and if there is a torque value, it has been calculated using a lubricant. In fact there are so few non-lubricant applications it's not worth mentioning.
The lube used will change the applied torque because some are more slippery than others. Oil slippery but not in a good way for bolts vs. moly, very slippery and good for bolting. For the car, a standard anti-sieze is good. For special applications the lube would be chosen taking into account many different aspects of the use.
In a typical industrial application, 90% of your turning force is used to overcome friction, so a change in lube can have a big effect on the residual load. The residual load or clamping force, or elongation is what engineering is interested in.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
