Old 08-18-2016, 07:07 PM   #13
steved0x
steved0x's Avatar
Originally Posted by DWBOX2000 View Post
Stupid question which way do I turn the tap. I would think clockwise but my track record is not so hot.
Yeah clockwise. Then blow it out with some brake cleaner. Gently test fit the helicoil but just a turn or two. The red loctite that mother in there. Don't forget to knock the tab off the end of the helicoil after you set it. Wait a bit for the loctite to set and then proceed with your installation.
I would only tap as deep as your helicoil is long, (or just a touch deeper) and then install so the helicoil is flush with the surface. Edit: I just saw your post. Drill down to the depth of your bolt. But tap and set the helicoil flush with the surface and red loctite it in so it is permanently installed, flush to the surface. Shouldn't have to cut the bolt.
Also did you get my pm, I have an extra stud for the brake bracket, send me your address and I will send it to you if you want to go the stud approach for that one.
