Old 08-18-2016, 02:37 PM   #1
hazardc
You need to pull the immobilizer out, open it up and let it dry. Once it's dry, clean with rubbing alcohol and a soft bristle toothbrush to remove any corrosion. Pay extra attention to the connectors that plug into the immobilizer.
There is an emergency release cable for your front trunk located just inside the passenger side (right side) wheel well. You'll need to pull the liner back to get to it and even then it's a pain to see.
It's under the headlight kinda, isn't it? i had that headlight out and saw a loop
I don't even know how to pull the seats yet, guessing i need to grab the hex set
thanks for any suggestions.. is there any process to "relearn" the pill in the key or should it just be plug and go if it is going to work?
hazardc is offline   Reply With Quote
