Old 08-18-2016, 02:23 PM   #2
particlewave
You need to pull the immobilizer out, open it up and let it dry. Once it's dry, clean with rubbing alcohol and a soft bristle toothbrush to remove any corrosion. Pay extra attention to the connectors that plug into the immobilizer.
There is an emergency release cable for your front trunk located just inside the passenger side (right side) wheel well. You'll need to pull the liner back to get to it and even then it's a pain to see.
particlewave is online now   Reply With Quote
