Old 08-15-2016, 11:21 AM   #1
newBgeek
Originally Posted by rdonahe View Post
It's hard to tell as the wiring goes under the plenum but it looks like the leak may be up higher and traveling down the wiring where it's collecting on the O2 sensor bracket and connector. From the bottom side it is leaking both on to the exhaust as well as the crossmember in that area.
I also had a strange oil leak that seems to have sprayed the driver's side O2 sensor connector and suspected the power steering pump as I know it was losing fluid. After changing the pump and cleaning the connector, it has stayed dry.
My old power steering pump actually looked OK, but there is a small o-ring that comes with the pump and attaches on the high-pressure side. The old o-ring that I took out was completely flat, so I suspect that may have been the cause of the leak.
newBgeek is offline   Reply With Quote
