Old 08-15-2016, 06:16 AM   #1
DWBOX2000
The bolt is 6mm or just over 1/8" in diameter. Easy out is about 1/8 at it's widest point but I did not get it in all the way. (probably why it broke) There is not much room around the easy out to drill out.
I am amazed that everyone is saying there is no bit hard enough to drill into the easy out. I put a dremmel on it yesterday and ground a nice hole dead center into the easy out. Maybe I just keep doing that until its gone. Since the easy out is not so deep, not much is in the bolt to grind out. Obviously desperate for a postive spin.
Thinking outside the box for you engineer types"
The bolt that broke holds on a bracket that holds the brake line to the Wheel Carrier. Is there any type of glue that I could just glue to the bracket to the carrier? I'm getting desperate now. Ideas?
DWBOX2000 is offline   Reply With Quote
