This only works if the broken easyout is broken into steel bolt stuck into an item made of aluminum. I had it happen to me once and I took my mig welder to the broken bolt/easy out. You have to build a puddle high enough to where you can also weld it to a bolt. It took me about ten tries before everything came out. Because the piece I was working on was aluminum, the mig steel wire doesn't bond to the aluminum. I also didn't have the voltage high enough to melt the aluminum threads.
Woody
