Old 08-09-2016, 02:53 AM   #2
Auf los!
Auf los!'s Avatar
Thank you, MWS, that is an excellent thread you found. Guess I need to add a little more so that the ends of the brackets are submerged.
I am personally not sure if the "L" brackets are metal or plastic. I wasn't about to stick my finger in there to feel them. But the plates in the battery are metal, so I wouldn't be surprised if they were metal.
My battery is on the Porsche maintainer for several weeks during the winter, and it is that charging that must be contributing to the fluid loss. There was some residue from vapor escaping around the caps. Once I've got the battery filled, I will check the levels in the Fall and in the Spring.
Thanks again. Looks like I narrowly avoided a dead battery call to AAA.
2001 Boxster S 6-speed, 2013 Boxster S PDK
Auf los! is offline   Reply With Quote
