Old 08-05-2016, 09:19 AM   #1
CrisZenithBlue
CrisZenithBlue's Avatar
an oil pressure light, even a solid one that's intermittent is something you want to get addressed ASAP! i had the same engine same mileage and when i got a light 2 months ago my engine was already toast. it happened when i was hard on it for about an hour, car started shaking, pulled over and light came on. light went away and it drove what seemed to be normally but when i went and pulled the filter right away it was full of metal.
hope your fate is better than mine though i really do!
if you're so close to an oil change i say drop the oil now and check the filter and housing carefully and see if it's clean. maybe it was just older thinned oil and the heat.
good luck!
CrisZenithBlue is offline   Reply With Quote
