Old 07-31-2016, 03:33 PM   #5
LEJ
If your car is a 2000 model year and you haven't changed the coolant tank, it's leaking. especially since you live in Gilbert AZ, (HOT WEATHER) Look under the car and you'll probably see white crusty stuff on the back right rear suspension. That's coolant. Even if it's not leaking now, it will leak in the near future. As explained to me, it may only be a hair line crack but as the tank heats up it turns into much larger opening. My 2001 was leaking ever so slightly and a leak, is a leak, regardless of the quantity. New coolant tank but still some coolant smell as it will take a long time before it goes away (mentioned above)
LEJ is offline   Reply With Quote
