Old 07-30-2016, 01:55 AM   #19
Escy
Originally Posted by Bayley View Post
The fuel pump was a little tricky. The Porsche engine controller uses a low side side to power the fuel pump relay, but the Chevy ECU uses a high side switch. I had to swap the wiring around in the fuse box, but I got it to work with the factory Porsche relay.
Can you remember what you did?
Escy is offline   Reply With Quote
