Old 07-28-2016, 04:10 PM   #2
tsasu360
Originally Posted by jcslocum View Post
Can you hear the motor run when closing the door as if the window would go up? Maybe the regulator is all stretched out. Other than that, I would guess that the switch in the handle is bad and causing an issue.
Thanks...good point on this test...
The motor does not try to lift the window when the door closes...whether the handle is pulled or closed, once in the state that the window went down it's pretty much set and won't come back up unless activated with the window switch.
So maybe this is not a regulator issue but why would the inside and outside handles lower the window to different heights?
tsasu360 is offline   Reply With Quote
