Old 07-23-2016, 08:13 PM   #3
madmodz
madmodz's Avatar
You cannot just by pass the alarm unit with wires, the DME is programmed to wait for a signal from the alarm system before allowing the car to start. That programing is not going to go away..
Before going the replacement route, pull the seat and the alarm module, allow the carpeting to dry completely. Open up the alarm box and flush it with either electronics cleaner or simple isopropyl alcohol, allow to dry. Change the fuse in the alarm unit. Reinstall everything and it will probably work (better than a 50% success rate on this).
thanks Jeff!
Thanks Jeff
My car wouldn't start. I had stripped the interior to reupholster and dynamat everything. I had no ideal the alarm module had its own fuse. As soon as I picked it up the connector fell off it. I was like-hell yea! That has to be it. It was!
Thanks to all who contribute and ask questions. Once again the search button saves another boxster.
madmodz is offline   Reply With Quote
