Old 07-23-2016, 07:35 PM   #5
911monty
911monty's Avatar
Orangeman Don't know but if seat is still out you can test the motor by supplying 12 volts to the 2 pins by the coding pin. Supply 12v+ to one and 12v- to the other. Then switch polarity to reverse. It is important to not run motors in one direction too far as the track operates on some infinity loop. If you go too far either direction the Seat back release will not work.
