Old 07-22-2016, 09:12 AM   #1
onefasazn
Looking good, thanks for the great write-up
Can you somehow set the unit to report faults/codes as they occur? real-time? or needs manual scanning
thanks
It will not do auto reporting of CELs. No Scangague I've used has done that, although I haven't really checked the manual. You can check it out here:
http://www.scangauge.com/wp-content/uploads/documentation/sgii-legacy/SG_Manual_2-51.pdf
Its good to read global OBDII codes on the fly, but I would use a Durametric for proper diagnosis.
onefasazn is offline   Reply With Quote
