Old 07-19-2016, 10:12 AM   #1
san rensho
"One thing i did notice is that when it starts to heat up at idle, if I raise the idle to about 3k, the needle starts to go down.
Sounds like the w/p is not efficient at low rpm. Had a previous(metal) w/p failure gouged out the crankcase half and caused excessive clearance between the impeller blades and the housing?
Have plastic impeller fragments from a previous failure blocked the system? Try looking in the heat exchanger.[/QUOTE]
The water pump that came out was the original water pump and all of the impellers were perfectly intact. So I can't think that the previous water pump cause any problems. I'm going tobleed the system again with the u view And see if that makes any difference.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
