Old 07-19-2016, 08:48 AM   #1
Gelbster
"One thing i did notice is that when it starts to heat up at idle, if I raise the idle to about 3k, the needle starts to go down.[/QUOTE]
Sounds like the w/p is not efficient at low rpm. Had a previous(metal) w/p failure gouged out the crankcase half and caused excessive clearance between the impeller blades and the housing?
Have plastic impeller fragments from a previous failure blocked the system? Try looking in the heat exchanger.
