Old 07-14-2016, 10:56 AM   #1
Porsche9
Porsche9's Avatar
As stated in the other thread, check your motor mount and change the gear oil and only put in Porsche approved gear oil. The detent is a nice upgrade to eliminate the 2nd gear pop out but since you mention grinding this is not likely to fix you current issue.
You don't mention if it only does it when cold or in all conditions. If the other fixes mentioned does not take care of the issue then it's your second gear synchro and if that's the case you need a rebuild.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
