Old 07-11-2016, 07:12 PM   #2
911monty
911monty's Avatar
If you use a power bleeder such as the Motive you can just bleed the brakes. BUT if you are going to attempt to pump the brakes with the master cylinder to bleed, then you will need to bench bleed the master cylinder first.
