Old 07-11-2016, 11:42 AM   #2
Myoung73
That's the tension cable. The ball end broke off and should still be attached to the top ball. You can order a new one pretty cheap. Bottom one pops off / on and top one has a little pin you need to slide in after popping the ball on. Do a search for tension cable. Very easy.
2003 Boxster S
2004 Carrera Cab
Myoung73 is offline   Reply With Quote
