Old 06-30-2016, 07:03 AM   #1
thstone
The alignment tool may or may not help. It will align the cables so the shifter engages the gears properly but won't do much for a worn out shifter with bushings that have 1" of slop in every direction.
If you don't have any problems with actually engaging gears, then you probably need a new shifter (or new shifter bushings).
