Old 06-29-2016, 09:40 AM   #4
JonineG
Thank you guys for the recommendations. The dealer I went to is located in Davenport, Iowa. I just can't believe they could not fix it. I don't think they tried very hard. This happened back in October. Since we put the other immobilizer in it I have been driving it to work and back. I just ignore the ABS warning. I did attempt in March to make the trip to Florida to have the mechanic there reset or reprogram it for me. I made it to St. Louis and the water pump and serpentine belt broke. Dealer had replaced the belt in October also. Car trailered it back home and replaced the water pump and belt. I hooked it up to my Durametric and most all the codes are coding and programming errors. I will give your recommendations a call and see if they can help me out. Thank you for all your help!
JonineG is offline   Reply With Quote
