Old 06-28-2016, 07:36 AM   #15
Nine8Six
Nine8Six's Avatar
...sometimes the IMS and crankshaft bearings fail just because of the two engine half casing tolerances.
That's an easy fix; just use a "Roller Bearing" lollll
The roller concept was designed for trains and bridges. They are so resistant your casing (casting?!) and the bore tolerances in ref to its shaft axis will 'eventually' shift back and run-in/out true just like it was once when shipped to you from the factory
