Old 06-25-2016, 11:02 AM   #9
Nine8Six
Nine8Six's Avatar
A far larger factor than RPM is the harmonics of the shaft itself; most IMS retrofits still allow, or even encourage, oil intrusion into the shaft, which can set up strange vibrations as the shaft, now partially full of oil, accelerates under load; none of which is doing the rear bearing any good.
I know, makes you really wonder if the kit got balanced in that Finland backshop before each installations lolll That should have taken care of the harmonics at best.
Was just sayin RPM, often the easiest decision benchmark when CAE data is out of reach. Old formulas. Tons of engineer calculators available online that will let anyone know how much you'll be able to rev up that little sport car during those spirit drives (roller vs balls, etc). Not a taboo thing
MicroPoly - Maximum RPM Calculator
(J - why builders want rollers? any specific reason(s) to this?)
