Thread: Break pads
Old 06-23-2016, 09:00 AM   #1
peterbrown77
Originally Posted by Jay B. View Post
I want to attempt to change my brake pads for the first time on my 00 S and researching on youtube it appears to be straight forward on how to change these out. So my question is can I buy OEM pads at my local auto parts stores ( Auto Zone, Advance Auto ) or should I go to the dealer to buy them? I don't want to buy junk and I'm not sure what is on the car now so is OEM pads ok or should I upgrade? My car is just a cruiser and not tracked.
Just did mine on my '02 S.
I found it easier to remove the caliper first because the shims fit into the Brembo pistons and are glued to the pad. If you try to force them out, I think you're going to mar the red paint. Just remove the 2 10mm hex screws after first undoing the small hex head that holds the brake line to the knuckle. Then you can swing the caliper out and the pads will drop right in your hand (after removing the retaining pin and spring). Next, use a sharp tool (I used an old wood chisel) to get the shims off for re-use.
2002 Boxster S, Arctic Silver, 18" Turbo Wheels, 6-speed
peterbrown77 is offline   Reply With Quote
