Old 06-22-2016, 08:24 PM   #10
rexcramer
1997 Tip, 2018 Macan
rexcramer's Avatar
It sounds like your compressor may be done. No hi side pressure, with the clutch engaged, is bad. Is it making a lot of noise? If you have 30 on the low side, you should also see 30 on the hi side. It is a closed loop.
