Old 06-20-2016, 07:54 PM   #10
AZ986S
AZ986S's Avatar
Originally Posted by Simon Wooldridge View Post
Hi folks.
I'm guessing this question has been asked many times, but what tyre pressures do people use in their Boxsters? I drive a 2003 'S' (usually very slowly) and am running 30/36 lbs. The car has 18 inch wheels with nitrogen filled rubber at present in its
Front: 225/40/R18
Rear: 265/35/ZR18
Falkon tyres.
I'd be very glad of your insights / ideas.
Thanks heaps.
I have an 02S and 18 in tires, Michelin Pilot SS. I like to run a little harder, 32-34 psi front, 36 psi rear. But then, I this is for speed not cushy city driving...
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
