Old 06-22-2006, 07:17 AM   #2
insite
what year is your car? is it an s? is it manual or tip? assuming it's a base 986 with a manual transmission and no M030 package, you have:
Front: 23.1 mm diameter, 3.4 mm thick
Rear: 18.5 mm diameter, 2.5 mm thick
for the money, you can't beat the M030 in my opinion. still very comfortable while providing some extra stiffness. the front sway bar in the BASE M030 package is the same as the BASE boxster S. there is a boxster S M030 front, though, that is even thicker:
Front: 24.0 mm diameter, 3.8 mm thick (21% stiffer than stock)
Rear: 19.6 mm diameter, 2.6 mm thick (25% stiffer than stock)
the part numbers are :
M030 Front 'S': 996.343.701.10 ($105.28 from Sunset Imports)
M030 Rear BASE: 986.333.701.20 ($ 70.12 from Sunset Imports)
make sure to get the BASE rear sway; it's a lot thicker than the 'S' rear M030. also get the corresponding bushings (about $20 for all of them).
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
