Old 06-18-2016, 07:59 AM   #13
BYprodriver
BYprodriver's Avatar
The heads are the same casting including the bolt hole bosses. Depending on application (3.4 or 3.2) holes are drilled & taped for bolt on accessories & combustion chambers are finished with 3cc's less volume for the 3.2L to maintain compression ratio with smaller bore size. Valvetrain is the same.
(corrected post from original text)
