Old 06-17-2016, 05:02 PM   #18
BYprodriver
BYprodriver's Avatar
How does he resolve the click on fitting that is molded into the plastic intake behind the throttle body?
Maybe increase the hose diameter to go around it & get clamped in place. The connecting tube is 26mm diameter with a 28mm "barb".
Increasing hose diameter may reduce the vacum signal enough to effect ring seal though.
I wonder why the 97 AOS with the horozontaly oriented diaphram was replaced with the vertically oriented diaphram?
