Old 06-12-2016, 04:16 PM   #12
TypeA
Rookie
Cool, thanks for the help. Directly below that is this three way connector with two very brittle lines. The broken line you see coming off the right was trapped under the passenger side intake, did the end of this line formally have a connector that plugged into the vac reservoir? Or is there another vac line running under the passenger intake that Im not able to see? Im not seeing another stray line that might go into the vac reservoir but this broken line has no end and wondering if it continues under the intake as another vac line to another destination, or the end has simply broken off and its the line that indeed plugs into the vac reservoir....
02 Seal Grey 5 Speed
TypeA is offline   Reply With Quote
